Valve Covers.. Old problem, New Idea
Old Feb 18, 2005 | 09:16 AM
  #16
Crazy95Z's Avatar
Re: Valve Covers.. Old problem, New Idea
Just a little update for anyone that was interested. I did go ahead and space out the entire accesory bracket from the block and the pulley from the crank hub. Ended up using 4 flat washers on each bolt and so far it has worked flawlessly. I've only driven the car for about 100 mi. so far but it seems to be doing fine. I am however constantly checking the bolts on the pulley/balancer assembly to make sure they stay tight each day. Hope this might work for someone else too.
Old Feb 18, 2005 | 07:57 PM
  #17
Bud M's Avatar
Originally Posted by 1-bad-z28
I had a buddy that put tall valve covers on his and he had a notch cut out of it and welded back together. Worked perfect.
Thats what I would do
Old Feb 18, 2005 | 10:45 PM
  #18
96camaroz28lt4's Avatar
Wouldn't you have to worry about power steering etc.?
Old Feb 19, 2005 | 01:15 AM
  #19
sssalah's Avatar
Power steering pump is fixed to the main bracket by 2 bolts as well as the tensioner. Thats what he did, he spaced out the bracket and probably removed the compressor rear bracket and maybe alternater supports.
Old Feb 19, 2005 | 10:35 AM
  #20
Crazy95Z's Avatar
Yea, I don't have the alternator rear brackets there anymore and I have a/c delete also.
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
Jazsun
Dec 29, 2014 12:14 PM
