Valve Covers???
Old Sep 26, 2007 | 08:13 AM
Rich_z28's Avatar
Valve Covers???
When going to a 1.6 rocker arm on a stock cam is it necessary to buy taller valve covers? Thanks
Old Sep 26, 2007 | 08:40 AM
SS MPSTR's Avatar
nope.
Old Oct 4, 2007 | 11:28 AM
Rich_z28's Avatar
What about going with 1.7's is that possible on stock tuning and valve covers? I'm definately going with 1.6 but was considering the 1.7 if it's not alot of trouble. Thanks again
Old Oct 4, 2007 | 11:36 AM
SS MPSTR's Avatar
Mine hit when I had them...I'd personally stay away from 1.7 rockers.
Old Oct 4, 2007 | 11:45 AM
Rich_z28's Avatar
I'm staying with a stock cam. Were yours on a stock cam also?
Old Oct 4, 2007 | 11:51 AM
Rich_z28's Avatar
Whats the lift good to on stock springs?
WS6T3RROR's Avatar
Just skip the 1.7 rockers they're not a good idea for a whole laundry list of reasons. They do have thier application but its just not yours.
all you have to do is flatten out the support rail on the intake side of the valve covers, or you can cut it out of there with no ill effects, i prefer to cut it but i'm a little lazy.
Old Oct 4, 2007 | 02:31 PM
Irish350's Avatar
mind if i ask when 1.7s are applicable? ive only seen a handful of lt1 guys using em, so i gotta wonder why one wouldnt use them (with aftermarket springs of course)
Old Oct 4, 2007 | 03:15 PM
WS6T3RROR's Avatar
they're applicable on certain 18* and other race setups where you cant physicly fit a taller cam lobe into the current cam tunnel i've worked on setups that run 1.9 and 2.0 rocker ratios, but they are RACE ONLY. and those are only usually in cases where boring the cam tunnel out to a larger size like 55mm or even 60mm to get a little extra room isnt allowed.
The reason most on here dont run them is because its hard to keep high ratio rockers like the 1.7's under control over 6500 rpm without running a solid roller with the heavy stock or stainless steel valves that most on here use, in short its just too much brain damage most of the time, sure you can cut a cam to work with 1.7's and stay under control but why go through the hassle. plus the wilder your rocker ratio gets the more funky your pushrod placement is the more force you're putting on the lifter plunger, its just hard to justify on a juice roller.
The other reason is that even on a cam heads lt1, from 1.5-1.6 rockers will be about a 15hp gain, but from 1.6-1.7 is gonna be 5 if you're lucky and dont start rattling the valves.
btw 1.6's on stock springs are a little sketchy but its been done for pretty decent periods of time, 1.7's is a no go and you will break stuff.
Old Oct 4, 2007 | 09:29 PM
Irish350's Avatar
word, thanks for the info
my topends already set, i was just wondering
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
