Valve Covers
Old May 22, 2006 | 07:53 PM
Stroked94z's Avatar
Valve Covers
I was just wondering if any of yall have tried to buy tall aftermarket valve covers for the LT1 and if so what kind they were. We just installed the Comp Cams Pro Magnum rockers and they are very close to the stock valve covers and we would like some more clearance. Thanks for the info.
Old May 22, 2006 | 07:59 PM
TransAmGT94's Avatar
Re: Valve Covers
you will have to grind on the casing for the alt or relocate it with any you use.
Old May 22, 2006 | 08:01 PM
Stroked94z's Avatar
Re: Valve Covers
So i can just buy any kind i want and just get them machined to fit?
Old Jun 24, 2006 | 08:29 PM
Severous01's Avatar
Re: Valve Covers
by machined you mean hammer??? sure. or you can die grind the "ear" off the back of the alternator and it'll be fine...as long as they arent more than about 1/4" taller than stockers.
so if you're planning on using the 1/2" spacers from moroso...wont work, if you are getting "high performance stock replacement" units, they'll work without relocating the alt.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
