valve cover wont fit?..or will it?
Old Nov 30, 2003 | 02:23 AM
whitedakota's Avatar
Question valve cover wont fit?..or will it?
i just had my heads redone and new springs and 1.6 comp. mag. roller rockers, (self-aligning) they arent set just the rockers on on there with the nut finger tight, have to wait till tommorrow to set the lash on them...well anyhow i was gonna just set the valve cover on there to keep the valve covered up and the valve cover wont go all the way down flush with the heads.
is this because the rockers dont have the springs pulled down or what not???
info greatly appricated.
steve-o
Old Nov 30, 2003 | 02:35 AM
96z's Avatar
96z
With the promags and the stock valve covers you need to bend the metal lip down that runs between the rockers. You will see it on the bottom(valve part) part of the cover
Old Nov 30, 2003 | 06:06 AM
FuryZ28's Avatar
I cut mine out with a dremel & a cutting disk...
HectorM52
Jul 30, 2017 11:46 AM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
