Valve Cover Holes
Old Feb 1, 2009 | 12:12 AM
deerslayinrenek's Avatar
Valve Cover Holes
I just got new aluminum valve covers for my z28 and the holes are different sizes. What do you guys do to get the oil fill and the pcv hose fitting to fit. Thanks
Old Feb 1, 2009 | 01:12 AM
lt1-xjs's Avatar
Go to the local auto parts store and get new caps and grommets.
Old Feb 1, 2009 | 12:56 PM
will they have a fitting so i can use my pcv pipe?
Old Feb 1, 2009 | 05:25 PM
You get a "grommet".... a rubber ring that pushes into the hole in the valve cover to make a seal. Then you push the elbow for the PVC fresh air supply hose into the grommet. You may be able to use the grommet out of your old stock cover.
Measure the inside diameter of the hole in your new valve cover. Measure the outside diameter of the plastic elbow for the PCV tube, and get a grommet that fills the gap.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
thenewkid
Nov 29, 2014 04:54 PM
