Valve Cover FABRICATION for 1.6 Rockers...
Is there any fabrication that needs to be made to the valve covers for the Promag 1.6 Rocker arms on my 95 LT1?
Thanks in advance,
Tyler
Thanks in advance,
Tyler
Yep, I had to clearance my stockers for the Pro Mags. It's the little tabs that are bend down. You'll see what I'm talking about when you go to install the valve covers. Start with the drivers side (easier on and off). A little time and some snips will get the job done.
Yeah I just bent mine down. Itll be easier to understand when the valve covers are off the heads. There a little straight pieces of metal that have a slight lip on them. you can either cut off the lip or just bend it down like I did, took 5 min.
Apr 3, 2015 10:54 AM
