valve cover clearence
Old Feb 9, 2004 | 03:30 AM
Zerosheaven's Avatar
will the stock valve covers fit with pro magnum 1.6 roller rockers installed?? if not which ones should i buy? can i re-use the gaskets?? thanks
Old Feb 9, 2004 | 03:37 AM
jkipp84's Avatar
There is some clearancing you'll have to do in order for them to work with the stockers. The little bent down tabs can be bent out of the way or cut off. You'll see what I'm talking about when you try to put them on, it's not too hard to do it. Sorry, I have no pics.
I went with some taller polished cas aluminum ones from eBay, but those actually required grinding to fit. I have to say it was worth it though, they look 10x better to me.
I think the valve cover gaskets are about $8 or so. No need to reuse the old ones when fresh ones are so cheap. You can get Felpro @ Autozone, Advance Auto, etc.
Old Feb 10, 2004 | 11:27 PM
any links?
Old Feb 11, 2004 | 12:32 AM
Brandon 95 Z28's Avatar
I have NSA Pro Mag 1.6 with gm guideplates, and they cleared my lt4 valve covers with no modifications.
Brandon
Old Feb 11, 2004 | 03:26 AM
jkipp84's Avatar
Originally posted by Zerosheaven
any links?
I just did a search on www.ebaymotors.com for lt1 valve covers and picked a set. They were about $110 shipped back then.
Old Feb 11, 2004 | 06:33 AM
12SCNDZ's Avatar
There's been numerous threads about this. You might want to try a search for "tall valvecovers". I'm using Proform tall aluminum covers (Sold through GM Performance).
Frank
Old Feb 11, 2004 | 07:06 AM
Bastardcat's Avatar
Here's a link I found that might be helpful:
Click
Old Feb 11, 2004 | 08:24 AM
SVT Killer LV's Avatar
http://web.camaross.com/forums/showt...t=valve+covers
you're welcome
Old Feb 11, 2004 | 09:28 AM
All_Z_Way's Avatar
They will work as long as the pieces are cut out.
Old Feb 11, 2004 | 01:14 PM
Tony Danza's Avatar
although i didnt make this thread i will thank everyone with the links- with the pictures, it helps me out big time
Old Feb 11, 2004 | 02:52 PM
thank you all, i modified mine to fit until my new new ones come in, one last question, do you know if i can reuse the gaskets (atleast temporarly until the new ones come in) or do i need to change them out twice? thanks
Old Feb 11, 2004 | 03:45 PM
I reused my gaskets
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
