valve cover clearance
Old Nov 14, 2005 | 06:42 PM
Chevycobb's Avatar
is there something I need to trim off the inside of the valve covers to make them clear the new rr's? i wouldn't think the 1.6's would have clearance issues, but the covers don't seem to want to go on and I can't tell what's holding them? any ideas? I would take pictures, but you wouldn't be able to see anything.
Old Nov 14, 2005 | 07:07 PM
z96's Avatar
z96
Re: valve cover clearance
cut off ears inside cover towards intake manifold leave ear on towards header also have to squeeze breather to remove center high spot
Old Nov 14, 2005 | 07:13 PM
Chevycobb's Avatar
I guess the ears you are talking about are the things that seem to be welded to each side and to the bolt posts? I guess i'll get my dremel out tomorrow and see
Old Nov 15, 2005 | 04:06 AM
95RagtopTA's Avatar
Below is a good write up--worked great for me. Just take your time and double/triple check to make sure none of the rockers are hitting before starting her up.... You can check by using some white assembly lube on the rockers, tighten the cover down, turn the crank (by hand or starter) and pull the cover to check for any greese spots...
http://www.hotss.com/Members/scott_vaca/pro-mag.htm
Old Nov 15, 2005 | 05:50 AM
Chevycobb's Avatar
great, thanks!!
Old Nov 15, 2005 | 07:04 AM
SS RRR's Avatar
It's always better to bend the supports rather than cut them off completely. That way the structural integrity of the valve cover is not altered.
Old Nov 15, 2005 | 08:22 AM
kingman109's Avatar
ha damn- wish i saw that site when i did mine-
it was like 4 in the morning- and we wanted to finish up bad - cut one side of supports out and just knocked the breather baffle out since i have a breather on the cover now-
Old Nov 15, 2005 | 09:18 AM
curly's Avatar
Off the subject....
Chevycobb, your video makes me want a GMMG even worse than I already do! Your car sounds awesome! I guess I'm gonna have to take the plunge .
Old Nov 15, 2005 | 04:28 PM
Chevycobb's Avatar
ha, thanks! it sounds a lot better in person though...video doesn't do it justice. I wouldn't trade it for anything. I hope it sounds even better with the new cam
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
thenewkid
Nov 29, 2014 04:54 PM
