valve cover breather?
Old Jan 27, 2005 | 11:49 PM
WingZero02's Avatar
I have a 94 camaro and I see these valve cover breather for camaros...where are they located?
Old Jan 27, 2005 | 11:59 PM
Got-LT1's Avatar
Re: valve cover breather?
I found one at Autozone once....
Old Jan 28, 2005 | 12:01 AM
camarokid24's Avatar
What are you asking ? Where to get them or where on the valve cover they would go?
Old Jan 28, 2005 | 12:02 AM
WingZero02's Avatar
by located I mean where is it in the car
Old Jan 28, 2005 | 12:03 AM
As far as I know they go where you oil fill tube is .
Old Jan 28, 2005 | 12:08 AM
sssalah's Avatar
On the passenger side valve cover in place of the pcv.
Old Jan 28, 2005 | 12:10 AM
Don't Look Back's Avatar
Correct. Except the piece you're speaking of on the passenger side valve cover is the CCV valve. The PCV is on the driver's side of the intake.
Old Jan 28, 2005 | 12:12 AM
WingZero02's Avatar
so which place is it? right or left?
Old Jan 28, 2005 | 12:16 AM
Is there any point to these on Lt1's besides to look pretty or do they provide some kind of befefit? also sorry for the bad info
Old Jan 28, 2005 | 12:21 AM
indieaz's Avatar
Well there is reverse flow cooling design - which helps a little with running higher compression ratios on pump gas and preventing detonation since it keeps head temps down more.
Also the advantage back in 1992 was the ignition system. Yes, the opti was an advantage...sorta.
Other than that? No, not really.
Old Jan 28, 2005 | 12:24 AM
If you were going to use a breather I guess you could put it in either spot. I imagine it would do the same job. However, I would like to maintain my filler neck, so I'd put it in the place of the CCV. All the CCV is is a plastic elbow with a hose to the throttle body in order to suck the ventilated gases in. I don't really see a benefit for switching from the CCV to a breather, besides aesthetics, but I don't see it hurting anything.
Old Jan 28, 2005 | 02:11 AM
1racerdude's Avatar
The piece in the rear of the passenger side valve cover with the hose going to the TB is wear the crankcase draws its fresh air for the PCV valve to suck out the fumes. It draws air through the engine air cleaner to get clean air. The drawback is at WOT the hose lets oil,from the vacuum of all the in rushing air, get sucked into the intake. A way to stop it is to get a small in line fuel filter and plug it into the line and let it lay,with the wires, on the intake/valve cover area or get a K&N valve cover breather which will probably stay wet with oil and make a mess if you have any blow by. Then get a rubber vacuum cap and put on the TB
connection.
The PCV valve is in the intake on the drivers side about the middle plugged into a hose and stuck into a rubber boot in the intake.
Old Jan 28, 2005 | 02:54 AM
97WS6SCharged's Avatar
You could always use a screw in type breather that replaces the oil fill cap. I use one on my blown car. $17 bucks + shipping & handling from Summit. Just look at the K&N section.
Old Jan 28, 2005 | 07:26 AM
Do a search about breathers. Injuneer has posted good explanations many times about it (he is probably tired of typing it out). In a nutshell, it really does nothing for you and it possibly harmful if you do not disconnect the complete PCV system. Breathers on a stock engine is pretty pointless.
Old Jan 28, 2005 | 11:52 PM
revtime's Avatar
After reading Freds explanation I took mine off and put the oil fill cap back on.
I installed a filter breather in the valve cover to help with any oil into the TB problems.
I orginally thought it didn,t make a difference as far as how the car ran but after some time I think the car runs better but it could just be me.
