valve clearance w/ 306 or GM 847
Old Apr 29, 2006 | 06:45 AM
jonesy's Avatar
was wondering if any machine work is needed ( to the pistons) to run either one of these cams.
thx,
jonesy
Old Apr 29, 2006 | 08:22 AM
Bersaglieri's Avatar
Re: valve clearance w/ 306 or GM 847
I have never heard of anyone having valve problems with either cam. I'd consult Comp or GMPP for more info if your real worried about it.
-Dustin-
Old Apr 29, 2006 | 09:08 AM
aboatguy's Avatar
I am running a CC cam with more lift than the 847/306 on a factory shortblock and NO DRAMA. If you install the cam and set it up correctly you will be fine.
Old Apr 30, 2006 | 05:49 AM
jonesy's Avatar
thx for the info
Old Apr 30, 2006 | 11:35 AM
marshall93z's Avatar
Has anyone actually checked it, though?
Old Apr 30, 2006 | 12:32 PM
Not sure if anyone has checked it, but since many folks are running cams as large or larger than the CC306 or GM 847 on stock bottom ends I doubt you have much to worry about.
-Dustin-
Old Apr 30, 2006 | 05:08 PM
Matts1994Z28's Avatar
you wont have any issues...
Old Apr 30, 2006 | 10:02 PM
toolmaker's Avatar
I had like .230 when I checked mine.
Old May 1, 2006 | 06:38 AM
chrism400's Avatar
Don't worry, there's plenty of room. I just checked mine with zero deck, .025 milled off of the heads, .039 Felpro gasket, and a .627 lift solid roller with 112 LSA installed at 108 and I still had .085. I've floated the valves on my car several times with the 224/230 and 1.6 rockers and didn't hit anything.
Old May 1, 2006 | 10:50 AM
jsetzer's Avatar
Im floating the valves right now with the 847, zero deck, .020 shaved off the heads and 2.00/1.60 valves. No problems.
sleeperZ96BT
Sep 9, 2015 08:28 AM
RX Speed Works
Jul 24, 2015 02:25 PM
1995Blackz28
Jul 20, 2015 09:34 AM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
