Vacuum with your 396?
Old Aug 11, 2004 | 10:04 PM
Hoostie's Avatar
First off, I dont know if this belongs in here, so sorry if this nees to be moved. My car ran fine and idles with some vacuum with the stock heads. I put the afr 210's on, with the lt4 intake and 58mm throtle body. Now the car runs like 8 inches or pounds (cant remeber which one they measure it in) at idle. The car is a 95, and it throws a code 33, low map sensor voltage, ie low vacumme. I do not have any vacuum leaks, becasue the car idles steady, and one would think that the idle would be all over the place if it had any ummeetered air coming in somewhere. Is this just the name o the big cam big head stroker game, or is something wrong? Can this be taken out with tuning? The cams duration is 242 248, with a 114lsb. The idle is set around 925, well so that is what the laptop says it idles at. Any hepl would be appreciated.
Old Aug 11, 2004 | 10:15 PM
Re: Vacuum with your 396?
Moving to LT1 Engine Tech.....
Old Aug 13, 2004 | 04:05 PM
Hoostie's Avatar
anyone?
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
