vacuum tube - need part # (evap to tb)
Old Jun 6, 2009 | 11:50 AM
96LT1TX's Avatar
Anyone have that part number (AHEM shoebox)? I am in need of it. I went to the track and realized that it is not there! I bet it killed my power big time.
Thanks in advance!
Old Jun 6, 2009 | 12:01 PM
Why not just (AHEM) go to Shoebox's part # page and look it up?
It's there.
Old Jun 6, 2009 | 12:49 PM
Whaddaya know, Fred was right.
http://shbox.com/1/1996_evap.jpg
Old Jun 6, 2009 | 01:23 PM
96LT1TX's Avatar
Hah, I did not look hard enough. Thanks guys.
How bad would it be to run without that vacuum line on? Just a bad vacuum leak? Could it cause any damage besides getting junk in the intake manifold?
Old Jun 6, 2009 | 02:09 PM
Again... hate to ask the obvious question. Why not just put a vacuum cap on the nipple on the throttle body (or tape it up, if you don't have a cap) and prevent the vacuum leak?
Its pulling in dirty air, bypassing the MAF sensor, and throwing off the A/F ratio, and possibly the idle speed. While the PCM may be able to compensate for it in closed loop, when you go WOT it may not be able to. Other than that, I can't think of any good reason to plug it up.
Old Jun 6, 2009 | 02:54 PM
flyinZ's Avatar
If its the hose I think it is, I've got a brand new one, I dont need anymore. No miles on it, just installed on the car and removed.
Old Jun 7, 2009 | 12:32 PM
96LT1TX's Avatar
Injuneer, it will be fixed and I will not start the car until then. I was having idle issues and my MPH was a little low. Thanks for the confirmation of what I was thinking was happening there.
Old Jun 7, 2009 | 02:24 PM
neil350's Avatar
I replaced that part recently, was pretty cheap.
Old Jun 7, 2009 | 11:23 PM
96LT1TX's Avatar
found it!
HectorM52
Jul 30, 2017 11:46 AM
blac94Z
Feb 6, 2015 10:40 AM
blac94Z
Jan 22, 2015 11:19 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
