vacuum at idle???
Old Dec 7, 2010 | 07:54 PM
rguy's Avatar
vacuum at idle???
how much vaccum should a stock engine pull at idle? I was thinking 17 to 22 but I'm seeing 12 to 13 in my '94.
Old Dec 7, 2010 | 09:11 PM
Re: vacuum at idle???
~20"Hg (= ~10"Hg MAP at sea level)
Old Dec 8, 2010 | 02:10 AM
MikeGyver's Avatar
12 to 13 is a little low. you should see about 15-17
Old Dec 8, 2010 | 11:55 AM
wrd1972's Avatar
Sounds like it has a non stock cam.
Old Dec 8, 2010 | 12:02 PM
n2ceptor's Avatar
My 93Z is around a constant 18 to 20"Hg at normal idle...
Old Dec 8, 2010 | 12:30 PM
Wild Willy's Avatar
Depends on cam overlap- and maybe exhaust restriction, though I bet that isn't a factor here. Should be pretty high, assuming good mechanicals- gaskets, valves, etc. Can you adjust the timing? What RPM are you idling at?
Nayr
Mar 3, 2023 08:34 PM
KYWes
Jun 14, 2022 06:52 AM
Double aught
Oct 2, 2015 11:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
tdigger9899
Sep 7, 2015 10:56 AM
