Vacuum goes between 16 and 17 psi. Why?
Old Nov 24, 2007 | 01:49 PM
mrmint69's Avatar
What would be the causes of lower vacuum? I get 16 most of the time than after a bit will go to 17 and hold for a while and go back to 16. It seems to be at 16 most of the time but will change instantly to 17 and then drop shortly after. This is at idle with the car warm and cold.
Old Nov 24, 2007 | 06:39 PM
OBE1 95Z28's Avatar
Vacuum is measured in mm Hg, not psi . RPM can change the amount of vacuum your car generates at idle. It's not uncommon for a cold engine to idle a bit lower until it warms up.
Old Nov 24, 2007 | 09:18 PM
Your blower will affect the vacuum in the intake manifold. Vacuum is typically measure in "inches of mercury" ("Hg). Standard barometric pressure (14.7psia) is 29.92 "Hg.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
