Vacuum Gauge readings at Wide Open Throttle
Old Mar 12, 2008 | 02:55 PM
Wild1's Avatar
According to "Wikipedia":
Wide open throttle (WOT) refers to an internal combustion engine's maximum intake of air and fuel that occurs when the throttle plates inside the carburetor or throttle body are "wide open", providing the least resistance to the incoming air. In the case of an automobile, WOT is when the accelerator is depressed fully.
At WOT, manifold vacuum decreases. Ideally, to preserve driveability and fuel economy, manifold vacuum should not fall any lower than 1" (mercury).
Why? Manifold vacuum should be at zero at WOT. I dyno'd my car yesterday and I was at 0.2inHG @ 4000 RPM and 0.6 inHG @ 6000 RPM. So, my assumption was that the shorty headers could be causing the restriction at higher RPMS.
Why would they state
Old Mar 12, 2008 | 03:07 PM
WS6T3RROR's Avatar
Because they're talking about carbed stuff and the signal gets funky when that happens?
Old Mar 12, 2008 | 04:08 PM
1989TransAm's Avatar
Right. You need a depression for the carb to work. With fuel injection atmospheric pressure would be the best at wot for a n/a car.
Old Mar 12, 2008 | 04:27 PM
And its normal for the vacuum to increase with the square of the air flow... if you increase air flow by 50% between 4000 -> 6000rpm (1.5X), your pressure loss (vacuum) would increase by a factor of (1.5)^2 = 2.25X. That would account for a large portion of the increase from 0.20"Hg to 0.60"Hg.
How did you measure vacuum? A U-tube manometer or the PCM's BAR minus MAP readings would probably provide the most accurate results. A mechanical vacuum gauge would be the least accurate.
Old Mar 12, 2008 | 06:59 PM
FWIW, I don't use Wikipedia as the source authoritly for anything.
Wild1's Avatar
Thanks for the great responses. We unplugged the vacuum supply to the HVAC and used that port. The Vacuum tool was part of the Dyna Tune machine (it was a rectangular black box) which then converted it to a digital signal. We then data logged the signal and overlayed the results along with AFR, HP, & lbs/ft.
The digitized reading was very detailed, not a lazy line.
So the increase from 0.2 inHG to 0.6 inHG is normal and not indicative of a restrictive muffler (exhaust).
This was on a 1995 Z28.
Old Mar 12, 2008 | 07:55 PM
96capricemgr's Avatar
an exhaust restriction would if anything reduce an engine's air demands not cause it to build vacuum at WOT.
The vacuum you are seeing is well within normal. I see more like 2" at WOT on mine.
Old Mar 12, 2008 | 10:39 PM
Wild1's Avatar
I'm pretty sure that if the vacuum builds in the intake manifold during WOT that there is an exhaust restriction. For example, if a Catalytic Converter is clogged (ignition misfire, etc) that the vacuum will read close to zero at WOT and will build dramatically under load during WOT. Since the exhaust can't poo the fumes, the intake cannot take as much out of the manifold which would leave more vacuum in the manifold.
Nonetheless, if you are seeing 2 inHG at WOT then I feel in the safe zone.
Old Mar 12, 2008 | 10:58 PM
Steve in Seattle's Avatar
Post
I dunno... I'm a BioChem major and find that even some of the most cutting edge bio-chemical topics are represented very well in Wikipedia. Just make sure you only take referenced items seriously if you have any doubts.
Same goes with my Neuroscience classes... very accurate from what I've read.
Maybe it's just the "more advanced" topics that get that much scrutiny (based on who would even know to contribute such info). More general topics considered "common knowledge" are less reliable IMO... then its about on par with google
Old Mar 12, 2008 | 10:59 PM
FryedClutch's Avatar
vacuum is caused by a restriction in the intake side
example
when at idle your throttle blades are closed closing off the intake from the atmosphere whilst the engine is still attempting to suck the air in there by creating a vacuum because of the throttle blades being closed which is your restriction.
At WOT the blades are fully open which will ideally feed the engine all the air it needs plus some if there is still vacuum there would still be some sort of restriction in the intake track.
anything that reduces the engines need for air will also reduce the chance of having a vacuum at WOT
i could be stupid though but im not usually
Old Mar 12, 2008 | 11:35 PM
marshall93z's Avatar
Dude, lay off the Wiki!
Old Mar 13, 2008 | 01:34 AM
tireburnin's Avatar
That vacumm is in the "normal" range. What is your intake setup and what are your mods?
Old Mar 14, 2008 | 12:06 AM
Wild1's Avatar
I have the following mods:
95 Z28/1LE - T56
Induction - SLP CAI, K&N dual air filters, 58mm Edelbrock TB, TB Bypass, 1.6 RRs Pro Magnum, Manley Pushrods
Exhaust - Edelbrock Ceramic Coated TES Headers, Off Road Pipe, Ex. Insert Cone, Edelbrock Cat Back
Ignition - Jacob's Ultra Pack Ignition, Coil, Trigger, 8.5mm Plug Wires, NGK TR6 Iridium Plugs
Drivetrain - Hurst Short Throw Shifter, SLP Alum Driveshaft, LG Torque Arm, GM 4.10s with Eaton Posi, SLP Lightened Flywheel and Centerforce Clutch Package
Cosmetic - RK Sport Back, ported heat extractors
Suspension - Hotchkis Front Springs, Welded Sub-Frame Connectors, Hotchkis Lower Control Arms, Hotchkis Strut Tower Brace, RK Sport LCA relocation brackets, Rear weight jacks by Ground-Control with Eibach 175# springs, and Spohn Adjustable Panhard Rod, Bump Steer Tie Rod Ends by Baer, 285/50R17 Goodyear D1-GS D3s, custom powder coated 17" wheels
290 RWHP/ 324 RWTQ - (July 2002) Before most of the mods
365 RWHP/ 361 RWTQ - (March 2008) Superior Automotive Ported Heads & Comp Cams 446 XFI added
Old Mar 14, 2008 | 12:11 PM
tireburnin's Avatar
That setup looks fine. Pull your filter and compare if there is a difference.
The headers you have aren't great for power, but probably aren't causing any vacumm issues.
Old Mar 14, 2008 | 12:28 PM
Wild1's Avatar
Unfortunately, I'm off the dyno so I can't run another test.
