Vacuum canister.
Old Sep 19, 2011 | 02:50 PM
LT1 POWR's Avatar
Vacuum canister.
What all does the stock vacuum canister supply. I've deleted my HVAC, is that the only thing? Just wondering if I need to remove it or plug the vacuum lines or what.
Old Sep 19, 2011 | 03:50 PM
JGuy07's Avatar
Re: Vacuum canister.
Can check the diagrams on shbox.com to verify you have everything...
Old Sep 19, 2011 | 04:11 PM
I just helps keep a reserve vacuum supply for the HVAC controls. If all that is gone, all you need to plug is the vacuum port on the intake manifold.
Old Sep 19, 2011 | 04:12 PM
LT1 POWR's Avatar
The only vacuum line I saw in the main harness comes from the intake manifold to supply vacuum canister and HVAC system and has a check valve inline. I can't think of anything else that is vacuum operated.
Old Sep 19, 2011 | 04:16 PM
That's because there isn't.
magman
Apr 15, 2016 03:08 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
