Vacum Hose
Old Aug 16, 2005 | 03:45 PM
JAG05's Avatar
Vacum Hose
On the 94 Lt1s there a vacum hose running from the passenger side valve cover to the throttle body. Is this one of those lines that runs exhaust gas back into the intake? And if so can I take this hose off and block off the ends?
Old Aug 16, 2005 | 04:13 PM
Re: Vacum Hose
No.
That hose flows air from a passage in front of the TB blades, to the passenger side valve cover. That air is pulled thruogh the crankcase and lifter valley, to pick up the blowby and other vapor that collects in the crankcase. The flow is provided by the intake manifold vacuum, via the PCV valve, located in the center of the drivers side of the intake manifold.
You could remove that line and install a valve cover breather. In effect, you will have created a small vacuum leak, since the air ends up in the combustion chambers, and in the stock configuration is accounted for in the air measured by the MAF sensor..... nothing the long term fuel corrections can't compensate for.
But you can not completely block off the hole in the valve cover, because you would eliminate the flow through the PCV system, and the crankcase can build up pressure, or condense out harmful liquids to contaminate the oil.
Old Oct 18, 2005 | 10:43 PM
1993Fast_Z's Avatar
Re: Vacum Hose
hey injuneer, could u please help me and my problem, search under "Fuel in Crankcase" i have that vacuum line and everything, but i also have a big problem with fuel Contamination in the oil...plz check it out...thanks
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
