Vaccum problem!
Old Apr 29, 2019 | 11:09 PM
Dro2135's Avatar
Vaccum problem!
Does anyone have or know of an easy to read diagram or detailed video on how to route all vaccum hoses without the smog pump on a 97 lt1?
Old Apr 29, 2019 | 11:31 PM
Re: Vaccum problem!
Probably depends whether the AIR pump recall was done on your car. Appears they added a vacuum operated shutoff valve, put a tee on the intake manifold vacuum nipple for the Opti vent system, and ran a vacuum line from the tee to the shutoff valve. Does your car have the shutoff valve and the vacuum line?
Courtesy of Shoebox
http://shbox.com/1/air_pump_recall.jpg
Old Apr 30, 2019 | 03:41 AM
Dro2135's Avatar
Re: Vaccum problem!
I don't remember seeing the shutoff valve but I'm not the one who took it apart so I'm not sure on that, I'm just trying to finish someone elses work you know how that can be I'm sure
Old Apr 30, 2019 | 06:09 AM
Re: Vaccum problem!
Basically, any vacuum that would have gone to the AIR pump, you just cap off at the manifold.
Old Apr 30, 2019 | 07:11 AM
Dro2135's Avatar
Re: Vaccum problem!
Ok thanks guys I think I pretty much have it now except Idk if the point on the throttle body drivers side right under the throttle cables is a vacuum or steam line
Old Apr 30, 2019 | 11:46 AM
94_6speedZ's Avatar
Re: Vaccum problem!
That capped fitting on your throttle body would have had a hose coming from the radiator. It appears that someone did the 'throttle body bypass' mod. There is no vacuum at that point.
Old Apr 30, 2019 | 02:20 PM
Chimera96's Avatar
Re: Vaccum problem!
The fitting on TB that is capped is for coolant. That has been bypassed, good. The one hard line that goes to the rubber elbow under the TB is vacuum and if original very likely needs replacing
Old Apr 30, 2019 | 02:26 PM
Re: Vaccum problem!
Except from the picture, doesn't appear to be capped (hard to tell). And of course it doesn't have to be. From an appearance point of view, I put a vacuum cap on it, and another on the similar connection on the opposite side. It's a coolant passage.
Old Apr 30, 2019 | 02:30 PM
Re: Vaccum problem!
And this is the rubber elbow that is referenced above:
Courtesy of Shoebox.
http://shbox.com/1/pcv_pipe.jpg
will.b.brown
Oct 31, 2012 09:11 PM
ScrmngChckn95
Jun 25, 2004 04:50 PM
crashin001
Jun 23, 2004 02:27 AM
TimbrSS
Advanced Tech
62
Apr 20, 2004 04:48 PM
X-Jester
Aug 7, 2003 10:07 PM
