V6 to LT1 swap
Old Nov 3, 2003 | 08:49 PM
CMANZ28's Avatar
V6 to LT1 swap
I just recently bought a 1994 Camaro RS with a 1993 LT1 swap. The guy I bought it from had a entire wrecked 1993 Z28 parts car and claimed he swapped everything. I can tell the entire front susp. was changed, along with the wiring and dash cluster, and the trans. He put a 700R4 in it. From what I've found out..the 700R4 came stock in a 1993 Camaro.
I was just wondering what are some things I would need to check to make sure it runs flawless come spring when I get it out. But hey for only $2200 I didn't think I could go wrong!
Old Nov 3, 2003 | 10:10 PM
94-3.4's Avatar
I would check your fuel pressure to see if he changed the pump. When i did my swap i left the stock pump and right now i am running 10psi less than i should which is causing some problems.
Old Nov 3, 2003 | 11:04 PM
onoiocoko's Avatar
if u want to see if he changed everything, i think the front sway bars are different sizes, the diffirential should have lsd and rear disk brakes, maybe check the fans and radiator.
Old Nov 4, 2003 | 11:15 AM
CMANZ28's Avatar
Thanks for your help, but how would you check your fuel pressure. Also what should it be at for a LT1? The entire front susp. was changed. He unbolted it as a unit and put it on the '94. I changed the radiator to an Lt1 reverseflow one. Would the stock single fan be able to keep the LT1 cool? I only have the larger single one.
Old Nov 7, 2003 | 07:35 PM
onoiocoko's Avatar
maybe get a fan switch or a programer to change when it comes on so it is on more.
Old Nov 7, 2003 | 07:54 PM
CMANZ28's Avatar
Thanks..Would a 180* thero. help too? I also have the stock rear end for a v6. Its got 3:23 gears and is a one wheel wonder. Will it hold up w/ an LT1?
Old Nov 7, 2003 | 08:46 PM
I would find a dual fan setup for your car. LT1's came stock with 180º thermostats. The rear end may be iffy.
Old Nov 7, 2003 | 08:51 PM
CMANZ28's Avatar
When I bought the car I got the dual fan shroud with one fan. I would need to find another fan. The guy said he changed the entire wiring harness over. But the problem is I cant find the other plug for the secondary fan. My question is how would you wire the secondary fan in? Thanks
Old Nov 7, 2003 | 09:00 PM
The top part of this diagram should be the same or similar to your wiring. Maybe the plug is hiding somewhere.
Old Nov 7, 2003 | 09:17 PM
CMANZ28's Avatar
shoebox
Thanks a lot..I'll look tomorrow
Noer
Feb 28, 2015 11:29 AM
rocketman051894
Jan 30, 2015 03:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
