v6 to lt1?
Old Nov 8, 2006 | 08:24 AM
ss owner's Avatar
v6 to lt1?
I have found a 94 camaro v6 with a blown head gasket for pretty cheap, but I was wondering how much it would cost/ what parts would be neccessary to convert it to an lt1
I havent bought it yet, just a thought. I have access to a nice Lt1, and could get a computher pretty cheap. but wiring? exhaust?
like i said just asking for some info from those with previous experience
Thanks,
Old Nov 8, 2006 | 08:29 AM
2000GTP's Avatar
Here is a link showing what you need as a minimum: http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
It would help if you had an LT1 donor car and just swapped parts to the v6 car.
Old Nov 8, 2006 | 08:44 AM
ss owner's Avatar
thank you
I found a good deal, but not that good, too much ...
I,ll let that one pass, thank you for the quick info
Old Nov 8, 2006 | 08:59 AM
AlfredB18's Avatar
Actually, the link mentioned for the swap is somewhat of a bit overkill.
The v6 gauge cluster can be kept. Dakota Digital sells an $80 (+/-) tach signal interface that keeps that work of swapping clusters out of the equation...
Fuel pump will be fine for a street cruiser. For a full-out race car, well, you need more than factory issued fuel pump anyway...
Suspension...the v6 jazz will be fine. The 3.4L is a pig for what it is, so it's not like the front end will snap off from an LT1 sitting under the hood.
Rear axle swap isn't necessary. Like the suspension bit, great to have, but definitely not a huge must. Driveshaft from a v8 car is a must, pretty much.
You can use one fan for an LT1. Non-AC LT1 cars only use one fan anyway.
It's grunt work, but it's not rocket science. Myc ar cost me $200 and a project 1980 MGB roadster that cost me $350...it's easier to find an LT1 pullout than a young (mileagewise) 3.4L for cheap...
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
