Using RTV to protect OPTI from Waterpump leaks? Corrosion Harness
Old Feb 10, 2004 | 09:00 PM
ZDriver96's Avatar
For added protection of the Opti what does everyone think about putting a strip of RTV across the top of the opti. Any downsides to this?? too much heat trapped in the opti or anything by doing this?
Also for those who've had that corrosion on the eletrical plug that hooks to the opti. What about putting rtv on the wires that insert into the plug too keep water from seeping past the wires and down inside where the connectors touch the opti pins.
Also wrap a piece of electrical tape around where the plug connects to the opti.
What do u think of these ideas and has anyone done this.
Old Feb 10, 2004 | 09:14 PM
95BlackTA's Avatar
I put a strip of RTV around the entire opti where it comes apart. Been fine soo far. It wouldnt keep in any heat, cause the head escapes from the vents anyways(well mine is vented). RTV around it will never hurt. Actaully, I had a coolant hose leaking on the opti for like 2 days, and it hasnt shown any signs of failure at all.
maybe2fast
Mar 16, 2015 11:59 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
