View Poll Results: Does your LT1 leak?
Yes and proud of it.
144
59.26%
No. And I hide sandwiches behind the intake.
85
34.98%
This thread is worthless. And I own a box of Kleenex.
14
5.76%
Voters: 243. You may not vote on this poll
Useless poll! Does you lt1 leak?
Re: Useless poll! Does you lt1 leak?
Originally Posted by LS1_03
My intake leaks, but it doesn't drip onto the ground. I'll solve that for whenever I do a cam swap.
Sure does
I'm 99% sure it's from the rear main. I'm an idiot for not changing it when I had the tranny out for my clutch change
I always have some fresh drops on the driveway in the morning. I should really post pictures of my driveway. From my oil leaking, to spilled oil during oil changes, tire spray, you name it; this driveway is all spotted up
Damn that waterpump drive seal
. Its my only leak, and evey where I park I leave a spot about the size of a quarter.
I even took it apart and tried to fix it once. Man was I pissed when it was still leaking after all that work.
. Its my only leak, and evey where I park I leave a spot about the size of a quarter.I even took it apart and tried to fix it once. Man was I pissed when it was still leaking after all that work.
Had an intake oil leak - fixed under warranty
Pinion seal leak - replaced pinion yoke and seal, fixed leak, broke rear gear 2 weeks later. Now have a new 12-bolt.
tranny output seal leaked - replaced seal w/ new driveshaft twice, bent 1st al DS when tranny mount broke.
Now the only leak is the windshield washer tank.
Very small drip from the front main, and I believe its cause I switched to synthetic...actually seems to be getting smaller though, like perhaps the seal is breaking in to it....
Leaky hear too.....
im noticeing leaks or wetspots up by my heads..... hope its normal.... true lt1s leak from the intake i guess, mines wet back on top of the bell housing.... oh well right?
i have a small leak from the low oil pressure sensor in the pan. It leaks very slowly from there. A new sensor is $20 so if I ever get it and fix it then problem solved. But the motor blew sooo.........I dunno.
No leaks from the engine at 160k. But it did have the intake leak fixed by the previous owner (my cousin actually) around 120k. The pinion seal weeps/leaks though, and my driver's side axle seal is starting to go. I just did axle seals on my other car, too!
