View Poll Results: Does your LT1 leak?
Yes and proud of it.
144
59.26%
No. And I hide sandwiches behind the intake.
85
34.98%
This thread is worthless. And I own a box of Kleenex.
14
5.76%
Voters: 243. You may not vote on this poll
Useless poll! Does you lt1 leak?
Old Apr 28, 2005 | 01:08 AM
madwolf's Avatar
Lt1s and leaks are like hotdogs and mustard. So, let's see what the ratio for leaky LT1s to non leaky ones is.
Old Apr 28, 2005 | 01:20 AM
Skull Leader's Avatar
Arrow Re: Useless poll! Does you lt1 leak?
Does you LT1 leak? Me LT1 no leak no more. Me get it fixed under warrenty when me had warrenty. Friend helped me with cam swap, but he make good seal of intake.
Old Apr 28, 2005 | 02:59 AM
Mighty's Avatar
Useless answer: You forgot the "r".
Old Apr 28, 2005 | 03:18 AM
BlackIsSecksee's Avatar
no leaks
*knocks on wood*
Old Apr 28, 2005 | 03:52 AM
n2oblkz
Guest
Posts: n/a
Nope, my garage floor is clean.
Old Apr 28, 2005 | 04:01 AM
scott's94z's Avatar
engine oil, atf, and a drop of rear end grease every once in a while. your saying not all chevys leak???
Old Apr 28, 2005 | 04:37 AM
BoobSter-lt1-z's Avatar
1 drop of engine oil from the oil cooler seal and a leaking radiator....
Thats it...
Old Apr 28, 2005 | 06:07 AM
baron4406's Avatar
A bad power steering pump leaked so darn much it left a big puddle everywhere I went, it was so bad I can't tell if I have an intake/rear main seal/etc leak. Ley ya know in a week or two.
Old Apr 28, 2005 | 06:19 AM
psychocabbage's Avatar
Mine never leaked.. But perhaps I should of given it more time between tearing the engine down repeatedly.. We did dimple the intake when we had it off so it would be less likely to ever leak (old school trick).
Old Apr 28, 2005 | 08:30 AM
Mimitchi's Avatar
Yep, I have a fairly small oil leak. Not sure if it's my dinged-up oil pan or if it's just a gasket. Either way, I noticed the leak's getting a little bigger, because I'm starting to smell the burning oil and the puddles are a lot bigger than they were when I bought it in October. Kinda sucks, but then again, I'm only going to be driving it for a few more weeks. Then it'll be my brother's problem.
Old Apr 28, 2005 | 09:35 AM
StngStlkr's Avatar
Very small leak at the front seal.
WJH'sFormula's Avatar
My old one leaked from the intake....dimpled and fixed....
Leaked a little from the timing chain cover after heads/cam swap due to faulty operator skills...
Ah....how I don't miss working on that car...
Old Apr 28, 2005 | 09:38 AM
OutsiderIROC-Z's Avatar
Mine didn't leak til I had the timing chain replaced, now it drips a bit. Gonna fix that this summer. I hate oil leaks.
Old Apr 28, 2005 | 09:44 AM
PlaneCrazy's Avatar
My garage floor has a permanent oil spot.
Old Apr 28, 2005 | 09:52 AM
LS1_03's Avatar
My intake leaks, but it doesn't drip onto the ground. I'll solve that for whenever I do a cam swap.
