Used Hotcam, buy it or not?!?!
I just got an offer for a used, very good condition Hotcam for $100. Just the cam. Is this a good deal or should I say no?
Also, I've got 130K on the clock, but there is ABSOLUTELY nothing wrong with the engine. Should I be ok doing a cam change, or should I NOT do it and wait for a rebuild? I mean, it is a pretty mild cam.
Thanks in advance,
Kyle
Also, this is going to be run on stock heads.
Thanks in advance,
Kyle
I got 132k on mine, HOTcam and ported heads. Runs really good. You can get a HOTcam by itself new for $160, so I say $100 is a decent deal. Don't forget some 1.6 roller rockers, upgraded valvesprings and a new timing chain.
If I wanted to do the cheapest cam swap I could do (I'm not all worried about making HUGE power) what would the price be around?? Keep in mind I can get a Hotcam for $100. I can buy used parts too if need be (rockers, lifters, etc.)
I'm thinking about doing this just to see what I can get out of it for the cheapest!
So I'd need:
Cam, rockers, lifters, springs(have to?), timing chain. Would I HAVE to have tuning? Or will the hotcam run decent with stock computer?
Thanks for the help guys,
Kyle
So I'd need:Cam, rockers, lifters, springs(have to?), timing chain. Would I HAVE to have tuning? Or will the hotcam run decent with stock computer?
Kyle
You have to get springs and rockers.
You can reuse your stock lifters if you want, although at that mileage, might as well get some new ones. (or I can sell you mine with 40K miles on them)
You can get a stock replacement timing chain and yes, I would recommend replacing it and also the sprockets. (I also have the chain and sprockets out of the same engine)
Without any tuning it may run OK, especially if you have a 6 speed. Not with an auto though. To get the best results and driveability, I'd definetely recommend it.
I would not run used springs unless you could find the entire kit with VERY LOW miles.
I thin you would be ok with the cam,lifters and rockers used.
You can take the cam to a machine shop and have them check it out before you install it.
I wouldn't use a used timing chain or springs but if they had low miles I guess you could if you want the cheapest
Not to hijack this thread, but to help out and also ask a question.
Why would you have to run new rockers w/ a cam swap? I know the hotcam is rated w/ 1.6s and 1.6s would be nice. But for a low budget swap i don't see why you would have to get new rockers...
So I'd need:
Kyle
Kyle
I wouldn't buy a used cam unless I was going to have it checked and polished. So if you can get one at a decent price and figure an extra $50.00 for checking and polishing, I personally, would opt for a new one.
If the cam is knicked or the integrity is otherwise compromised, you might wind up with a much larger bill in the long/short run.JMHO
Ok, first off, if I do this I plan on getting 1.6 rockers. The hotcam is already mild enough with those, 1.5's probably wouldn't help much.
So what you guys are saying is that the used cam is somewhat of a turnoff? This guy is a friend of my best friend and he's taking his camaro in a different direction. He's a mechanic at a GM dealership so I figure if anyhing it should be in great shape.
So ok, I'm looking at 100 for the cam, how much would a set of GOOD, used rockers cost me? Then the timing set shouldn't be too much, then lifters aren't too bad (I think i've got a bad one anyways), and last, but definately not least, how much would a decent set of springs set me back?
Thanks for all the help guys, appreciate it.
Kyle
Kyle
carguyshu
Jan 22, 2017 11:19 AM
