URGENT will 95 a4 work in 97
Old Aug 2, 2007 | 01:48 AM
95fbformula's Avatar
I am selling my tranny to a buddy of mine and just want to make sure I wont encounter any problems when putting my a4 from my 95 in to his 97 I am sure I wont but felt like double checking.
Old Aug 2, 2007 | 08:18 AM
Sweetred95ta's Avatar
There aren't any differences that I'm aware of.
Old Aug 2, 2007 | 09:20 AM
Phantomhp's Avatar
Not sur 100% sure if they will be fine or not as I know you are going from an OBDI car to an OBDII so not sure if that plays a role in the tranny connections/signals.
I know I have a 94 PCM/Wiring harness with a 97 engine block and a 97 transmission and the only difference I had was the VSS (vehicle speed sensor) connection.
I am sure one of the resident gurus will chime in with an exact answer.
Mike
Old Aug 2, 2007 | 11:33 AM
Severous01's Avatar
you'll need to use the whole engine. you'll have to swap the whole timing and cam if you want to keep it a 97 style...the cam is different, and the timing cover.
other than that, you can use all parts from the 97 if you want OBD2, or you can run a 95 and older knock module if you want OBD1...with the 95 PCM. wire harness should be identical unless you had TC vs non-TC
Old Aug 2, 2007 | 12:08 PM
I think he is talking about the transmission.
urbaNHunter44's Avatar
the trans is pretty much the same, iirc
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
MJ_Z28
Aug 7, 2002 07:15 PM
