URGENT!!! TH400 flexplate question
Old Aug 25, 2005 | 10:42 PM
1995ta's Avatar
For those of you running a TH400, what flexplate are you using and where did you buy it? My engine machinist needs this ASAP so he can balance the assembly. Links would be EXTREMELY helpful.
Thanks in advance,
Bret
Old Aug 26, 2005 | 01:04 AM
revtime's Avatar
Re: URGENT!!! TH400 flexplate question
Bret
Motorsports of KC has an externally balanced SFI 168 tooth flexplate sitting on the shelf.
I think they might be able to get a nuetral balance one but you would have to call and ask.
Old Aug 26, 2005 | 08:11 AM
rskrause's Avatar
Moderator
If your motor is being internally balanced, you don't really need the flexplate as it is neutral balanced. Some people do like to check this, though I never do.
Rich
Old Aug 26, 2005 | 08:16 AM
kamba93lt1's Avatar
I run a B & M flexplate. Its SFI approved and works great. Bought it from Summit. I think it was about 89.99 or so.
ken
Old Aug 26, 2005 | 12:54 PM
1995ta's Avatar
ken
You got a part number by any chance?
Old Aug 26, 2005 | 12:58 PM
rskrause's Avatar
Moderator
What you need is no different than any other neutral balanced 153-tooth Chevy flexplate, provided you are building an internally blaanced motor. Just be sure it has the bolt-pattern to match your converter. Most of them have dual bolt patterns to fit all of the GM style converters.
Rich
Old Aug 26, 2005 | 01:55 PM
kamba93lt1's Avatar
The B & M part # is 20238 It has a 10.75 bolt pattern.
ken
Old Aug 27, 2005 | 07:22 AM
CANTONRACER's Avatar
Something to be aware of....you put a 168 tooth flexplate on your car...what brand starter have you been looking at?
I bought the smallest starter Summit Racing had...6.5 lbs, dinky little thing...barely fits still.
Old Aug 28, 2005 | 06:12 PM
1995ta's Avatar
What starter should I get?
Old Aug 28, 2005 | 09:38 PM
I bought this one.
That is the smallest one they had one display. It barely fit though...Kook's headers really got in the way.
I was surprised that this 6.5 lb. unit only weighed a couple of pounds less than my stock starter.
Old Aug 28, 2005 | 11:07 PM
1995ta's Avatar
I just bought the Flexplate (listed above) from summit for $108 shipped to my door. Its a 153 tooth...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Nostang 96z
Sep 15, 2002 10:15 PM
MJ_Z28
Aug 7, 2002 07:15 PM
