Urgent Stock Computer&comp Cam
Old Apr 16, 2004 | 10:46 PM
N&MZ28's Avatar
I just got the Crane CC05 Cam and Headers with some other bult ons and needed to know if the car will run with the stock computer?
And if it will run, will it hurt anything to drive it like that? All advice is welcomed.
Old Apr 16, 2004 | 11:39 PM
med_reject's Avatar
i have a cc304, no tuning. the cam sucks by the way. The car runs fine, but if th eweather is cold, it wont start unless i give it some gas. And even then, it will run very rough, sounds ugly, until it warms up. I can imagine a cc305 being even worse, but probaly ok during the summer.
Old Apr 17, 2004 | 01:51 AM
disco192's Avatar
It will run. It wont hurt anything. It takes a little while for the computer to "learn" what is goin on. You will notice that the computer will make adjustments and run better after a few days. If you want it to run better just send the PCM out to get tuned. Best results will come from a dyno tune.
Old Apr 17, 2004 | 02:02 AM
StrokerWannaB's Avatar
PCMforless.com Does Lt1 PCM's for 175. i looked into it for when i get my 355 built. They do good work from what i hear. People from this site sent me to them.
Old Apr 17, 2004 | 10:58 AM
stereomandan's Avatar
I forgot his exact username, but it is something like '97bowtie
He ran the CC305 with headers for a long time with the stock tune. Ran good times too.
A tune is the best way to go though.
Dan
Old Apr 18, 2004 | 08:47 AM
96capricemgr's Avatar
On an old car would you swap cams and then not rejet the carb or reset the timing?
Well that is exactly what not reprogramming the computer is, if you aren't going to retune it don't bother swapping the cam.
Due to some laptop troubles I had to run on a stock tune(Caprice) with a ZZ3 cam, now yes the Caprice tune is setup for a smaller than f-body cam, but the ZZ3 cam is also much smaller than what you are looking at. It ran and drove OK but there was a lot of knock retard and it felt better overall with the stock cam, once I got the other issues fixed and the new tune it it was all better.
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
alliance12364
Mar 6, 2015 04:39 PM
Cam's maro
Jan 30, 2015 09:21 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
