Urgent Help Needed! Please...
Old Mar 6, 2008 | 04:23 PM
glenb1991's Avatar
Hey everyone, i was doing the throttle body bypass today, did everything as said to by researching posts on here... but now when i start the car, it dies, instantly. So i came in did some more research, and went out, and tried unplugging the maf, well the car stayed on, but idled at abotu 2500 then dropped down to 2000 after about 15 seconds. Im lost and seriously need help and quick, cars my dd and school calls in the morning, so im hoping to get this fixed tonight, if at all possible. Ill be on waiting replies for the next hour or so. so please dont hesitate to give me your opinions.
Old Mar 6, 2008 | 04:33 PM
Green96Z's Avatar
Make sure you reconnected everything. Did you spill any fluid, on the opti maybe?
Old Mar 6, 2008 | 04:37 PM
glenb1991's Avatar
no. i had a towel folder over itself to catch the fluid, and everythings connected back to where i took it from. its just weird that it dies when the maf is plugged in, but revs up when the maf is unplugged. any other opinions?
Old Mar 6, 2008 | 04:45 PM
Check the pins in the MAF harness connector for damage.
Check to make sure you didn't fold the rubber elbow under when you tried to slide it back on the throttle body, or tear it, creating a huge gap and allowing air to bypass the MAF.
Old Mar 6, 2008 | 06:23 PM
glenb1991's Avatar
well. thank you injuneer, i have a vacuum leak where the elbow meets the TB, and thats what was casing it, sadly i had to put everything back together to find this out, so all that work was done for no reason... so ill be doing it all over again once i get the elbow problem worked out.
Old Mar 7, 2008 | 07:12 PM
glenb1991's Avatar
Ok... nevermind, i went to lowes, got a rubber tube connector, tied it down with clamps, and stil lthe EXACT same problem as before, maf plugged in, instant die, maf unplugged, goes up to around 2k and idles... PLEASE HELP! I need this car up and running soon... thanks alot.
Old Mar 7, 2008 | 07:17 PM
dangalla's Avatar
make sure the bottom of the intake elbow where it meets the throttle body is not folded over, i had a terrible time getting mine on and had to spray it with white lithium grease and work it on with a screw driver
Old Mar 7, 2008 | 07:28 PM
glenb1991's Avatar
no rubber folded over checked multiple times... and clamps are on and theres a perfect seal... talked to a friend and said it could be my maf because of these symptoms im having with the car:
with maf plugged in-car starts at about 1500 rpm and dies down within a couple seconds, and the engine shakes horribly, and for the 5-10 seconds the engine was running, the exhaust smells nasty, it was so bad i saw my breath when i got out from turning of the car.
with maf unplugged- car starts at around 2000 rpm, slowly creeps up to 2300, then back down to 2000 and idles there, exhaust still smells, and when i cut off the engine, it has the same shake as with the maf plugged in...
solutions??
Old Mar 7, 2008 | 07:38 PM
dangalla's Avatar
it kinda seems odd that you maf all of a sudded took a sh.t but it is acting like that, or a massive vacuum leak. i would sooner believe you have a vacuum leak can you hear a sucking noise under the hood
Old Mar 7, 2008 | 07:53 PM
glenb1991's Avatar
well... i think i might have found it... gimme a couple minutes to go check what i think might be the problem and ill update ya.
Old Mar 7, 2008 | 08:26 PM
glenb1991's Avatar
nope... still no luck... ughhh.... pleaseeee someone help. haha. im dying here.
Old Mar 7, 2008 | 08:27 PM
ss.slp.ls1's Avatar
Fix or replace the intake elbow. Do you have a resonator...did you put it back?
Old Mar 7, 2008 | 09:35 PM
glenb1991's Avatar
resonator?? and i fixed the elbow.... but i guess imma have to buy the one of a guy locally, has a ceramic one for 50
Old Mar 7, 2008 | 09:39 PM
dangalla's Avatar
Originally Posted by glenb1991
resonator??
the long plastic piece that comes off the bottom of the elbow and goes between the rad and engine
Old Mar 7, 2008 | 10:00 PM
glenb1991's Avatar
oh, i had that covered off when i first got the car and put the K&N on, never had a problem with that before. So no reason that should mess things up... im giving up for the night, my fingers are killing me, gotta love f-bodies. lol. but any other suggestions while im catchin some z's? ill be checking on here bright and early tomorro.
