Urgent help
Old Mar 29, 2004 | 10:01 PM
SLeeper94Z's Avatar
Urgent help
Well for about 2 weeks i been trying to figure out whats wrong with my tranny , I got the trannys clutches replaced did not change the solenoids.. well I figured that one of the solenoids went out,So I purchased Autoxray off the net..
Scanned my car with AutoXray got Code 82 along with a few other codes such as egr and air code... well I looked up the codes on Shoeboxs's website..Code 82 referred to Transmission 1-2 shift solenoid circuit.... So I bought the Solenoids for the tranny today changed them, reset the Pcm along with the batt.. started car back up still the same, Rescanned got the same Code 82
this car is about to kill me and my wallet...Can anyone Please help me with this...are there any External wires outside of the tranny that would cause code 82, are there any fuses assoicated with the Transmission 1-2 shift solenoid circuit... if anyone could help me on this Please respond thanks
Old Mar 31, 2004 | 06:51 AM
SLeeper94Z's Avatar
TTT...
Old Mar 31, 2004 | 06:55 AM
AHARTZ28's Avatar
maybe a wire goy pinched or is is chaffing somewhere, the solenoid uses the same power circuit as the other solenoids do. it is more than likely a wire going to the PCM which is a ground wire.check on the passenger side where the wire harness goes through a metal holder. the tubing breaks there alot and chaffes
Old Mar 31, 2004 | 04:15 PM
SLeeper94Z's Avatar
After 3 weeks i think i fixed it
I got another tranny wiring harness and changed it , everything seems fine now thanks for your help
Fbodfather
41
Oct 6, 2008 12:09 AM
jy211
Mar 19, 2006 10:18 PM
RMC
Parts Wanted
Dec 12, 2003 09:20 AM
EaC95Z28
Aug 16, 2003 10:34 PM
mrgto
New England Area
12
Jun 17, 2002 07:23 PM
