Is upgradinig to a ported intake manifold worth it?
Old Feb 19, 2003 | 09:58 PM
Rodrigues's Avatar
I am wondering if a ported intake manifold would be worth it for my new setup. My mods and flow numbers for my heads are in the link below.
http://kak.com/camaro/heads.htm
Old Feb 20, 2003 | 06:56 AM
Rodrigues's Avatar
ttt
Old Feb 20, 2003 | 07:14 AM
MeanGreen97Z's Avatar
Should help. I dont see why it wouldn't do you any better than the one you have. I'd for sure get it. An HP gained is an HP earned. HaHa
Old Feb 20, 2003 | 07:31 AM
teke184's Avatar
i've read several posts over the past few years of guys porting their intakes or spending several hundrd dollars to have someone port it out and were VERY dissappointed. they were finding only a few (less than 5) hp gians from it. the only way i would consider doing it is if you are planning on doing it yourself and if you need to enlarge the holes for a 58mm throttlebody.
think about it, if guys are arguing that something that looks as restrictive as the stock 48mm throttle body is supporting 500hp engines without any problems, how much do you really think porting the intake is gonna do?
bottom line, if you are gonna do it for free...go for it, as stated evry little bit helps. otherwise don't bother
R@mpage
Apr 20, 2015 10:02 AM
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
