Upgrading cam-Can i get bye with--??
Old Apr 16, 2004 | 01:30 PM
Dwaynez28's Avatar
Question Upgrading cam-Can i get bye with--??
Hello, If my wife sezs ok I want to upgrade my CC-501 to either the CC-502 or the Hotcam. I already have the harden pushrods etc installed. Can i just replace the cam without having to upgrade anything else, like will the lift be to much for the pushrods,springs-I got most of the stuff as part of a LT-1 package. What stuff i got is in my sig. Thanks for your advice/opinions-Dwayne
Old Apr 16, 2004 | 01:58 PM
CeeBee94Z's Avatar
It really depends on what type of springs you have and what lift they are good to. I just put in a 224/230 and it is awesome. I have the EX 612 springs that are good to .600 lift I believe. Out of those choices you have though I say go with AT LEAST the hotcam because it is such a lot of work to go with something small and then have to replace it again kinda like you are doing now.
Old Apr 16, 2004 | 02:09 PM
19camaro71's Avatar
Good point, if your going to go throught allthe work to change a cam, go for one that will yield more results.
Old Apr 17, 2004 | 12:37 AM
Dwaynez28's Avatar
Thanks for the replies, just got back from work--The LT-1 package i got from Racenet had springs I "Think" good for around .550--Yeah i know its trouble and should have gone bigger--Not to big, i hear the CC-502 is a little bigger than the Hotcam on the lift--so do you guys think i can get by with just a cam swap alone? Thanks again Dwayne
Old Apr 17, 2004 | 01:06 AM
IrocManiac's Avatar
I saw at least switcht he springs too...even if you don't "need" it the freshening up couldn't hurt...but I'm the kind of person I don't like pushing limits of my parts because if something happens its expensive...helped a friend do a motor rebuild, we had it balanced blueprinted to 7000rpm, knowing we would only rev it 6000 rpm...needless to say it was built right, and he put 140k on it and still going...that was damn near 6 years ago now...moral to story, get better springs, you break a spring you'll be sorry...
Old Apr 17, 2004 | 01:15 AM
Dwaynez28's Avatar
Talking
Thanks for the help-----Dwayne----I almost forgot--what about the harden pushrods--How long should they be? Dont know how long the ones i have now.
Old Apr 17, 2004 | 07:08 AM
CeeBee94Z's Avatar
7.2 inches
13qtr
Oct 28, 2016 08:11 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
97SSdude
Aug 21, 2015 09:36 AM
