upgrading to 1.6 RR
Old Mar 30, 2007 | 11:42 AM
HottestZ28's Avatar
upgrading to 1.6 RR
I want to get 1.6 pro mag NSA comps, can I run them with stock springs.I heard at high RPMs they might coil bind I have my rev limiter at 6000 is this going to work?
Old Mar 30, 2007 | 11:47 AM
BUBBA's Avatar
Stock springs are marginal to begin with. You should get some good springs that will, at the very minimum, accommodate the increase lift of the 1.6s and optimally be capable of supporting whatever aftermarket cam profile you might install in the future.JMHO
Old Mar 30, 2007 | 12:17 PM
396D1SS's Avatar
if you are running a stock cam I would just throw a set of LT4 valve springs on. You can get them from gm parts direct for like 30 bucks
Old Mar 30, 2007 | 12:19 PM
2000GTP's Avatar
I wouldn't chance it with the springs, as mentioned above, run the LT4 springs at least and they won't set you back a ton of money.
Old Mar 30, 2007 | 12:39 PM
canuck94z28's Avatar
Lt4 Valve Springs
Do you have another place to buy these springs?;this stupid place does not ship/or deal w/CDN,S.
Old Mar 30, 2007 | 12:46 PM
If you aren,t putting in aftermarket cam go w/sa rockers and the lt4 springs.BTW I set my rev limiter@6200 and my shift points approx.300 rpm higher and bought Comp cams#1418-16.
Old Mar 30, 2007 | 12:48 PM
2000GTP's Avatar
Maybe try these guys: www.sdpc2000.com not sure if their shipping policies are any different though.
Old Mar 30, 2007 | 01:11 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
How difficult is it to change the rockers and springs? Does it matter if the engine is completely stock & has ~ 100K miles?
Jason or Dal from Shoebox's site might ship to Canada.
Old Mar 30, 2007 | 01:14 PM
mdenz3's Avatar
just call your local chevy dealer with the part number.
13qtr
Oct 28, 2016 08:11 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
