updated pics of true duals, finished!!
Old Feb 17, 2006 | 04:32 PM
  #16
2000GTP's Avatar
Re: updated pics of true duals, finished!!
That setup looks awesome man. I like how you used the Mountain Dew can to illustrate your ground clearance.
Old Feb 17, 2006 | 09:32 PM
  #17
camzaro28's Avatar
http://store.summitracing.com/defaul...=egnsearch.asp
is that the kit u used? if so i was looking at that a few days ago adn thinking about buying it, but wasnt sure if it would fit our cars. if it is not the one, do u mind sharing the part #?
thanks,
brian
Old Feb 17, 2006 | 11:40 PM
  #18
luckyou03's Avatar
Yes thats it, but if you have pacesetter LT, you need 2 x 4 1/4 extensions. The kit hooks up to hooker and jethot fine.
Old Feb 18, 2006 | 08:10 AM
  #19
Loadre's Avatar
Off topic: 9 inch or 12 bolt?
Old Feb 18, 2006 | 10:26 AM
  #20
luckyou03's Avatar
10 bolt
Old Feb 18, 2006 | 10:34 AM
  #21
Jeremy95TA's Avatar
TA Girdle.
Old Feb 18, 2006 | 11:47 AM
  #22
SoccerFEtus8's Avatar
I just want to double check this since now seeing some pics i think that will be the next mod. With the pacesetter LT's you welded a flange on the front of the X pipe, and then you also welded a section in between the first pipe of the "X" and the acctual "X"? If you were to be using Hookers, or jethot's you would not need to do either of those things?
And what size mufflers did you use...Over all lenght to make them meet up with the seatbelt bolt holes?
Old Feb 18, 2006 | 12:02 PM
  #23
LtsRace's Avatar
Damn, my ground clearance sucks compared to your!
Old Feb 18, 2006 | 12:13 PM
  #24
Jameslt1TA's Avatar
Ya, do you have a lift on your car lol. A soda can would fit under my pipes if the can was on its side lol.
I used the seatbelt bolts on mine and those same hangers. I posted pics allittle around a year ago. It works really good.
Old Feb 18, 2006 | 01:16 PM
  #25
luckyou03's Avatar
well I'm running the eibach drag launch springs, I hear they raise the rear just a little. I also have 17" wheels.
Old Feb 18, 2006 | 01:39 PM
  #26
luckyou03's Avatar
This post has been moved to: http://www.lt1engine.com/techaids/trueduals.html
Old Mar 8, 2006 | 08:46 PM
  #27
luckyou03's Avatar
this baby sounds orgasmic. I love it. Sounds like my LT1 with a hotcam turned into a cammed big block. I highly reccomend this to anyone thinking of buying a catback.
Old Mar 8, 2006 | 09:48 PM
  #28
haha I was just thinking about this mod again. I got some headers but have not had time to work on the car yet. still planing on this so happy to hear it sounds good.
QuickSilver02
Apr 7, 2015 11:12 AM
alphaauto
Jan 22, 2015 08:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
