update: car wont turnover but cranks - mystery
okay - posted few days ago about my car cranking but not turning over-
history : couple weeks ago installed cam / rockers and the usual goodies- first try she fired right up and idled perfectly - drove car home and noticed alternator wasnt charging. alternator then died and found out that it was due to powdercoating- also found a cracked coolant line above WP .
i replace line and checked everything- jumpstarted car and she ran while cables were connected but would not idle. got the new alternator - bolted in and go to start car and she cranks but wouldnt turnover. nothing has changed since last time. trickle charge the battery and still she wont turn over. so i have a warrenty on the battery so i got a new one and still wont turn over.
so far
ive checked and everything is plugged in and hooked up ( just in case i bumped something changine battery and alt.
when i turn my key to on position i hear my fuel pump kicking on and i have half a tank of gas.
pulled plug wire and im getting good consistant arch with block when trying to start.
what else could it be? only thing i can think is opti crapped out but after pulling the wire im not so sure. shes firing great.
any ideas?
so far
any ideas?
ChrisFrez
Nov 23, 2014 10:33 AM
