Unplugging 02 Sensor??
Re: Unplugging 02 Sensor??
No i don't think so. That will do nothing for you really. The proper way is with a data log, i think it has to with the voltage, and the BLM's or something like that. I have read some posts that people were looking at someones log and said that the BLM's on it were so far apart, and one was too low or high and it meant that the O2 in that side was not working properly.
Originally Posted by Camaro4LifeSS
I was wondering if unplugging an 02 sensor was an accurate way of testing to see if they are working properly?
Thanks,
JE
Thanks,
JE
I have an AutoTap scanner than I can use later this evening when I get my cord.What things do I need to list so I can get some help?My car acts up a little when it gets hot but at wide open throttle it's flawless.I thought I read a post saying "if you unplugg the 02 sensor and the problem goes away it's probably the 02".Maybe I read wrong though.
Thanks,
JE
Thanks,
JE
Unplugging stuff for troubleshooting is bad science, IMO. Record a data log, so that others can look at it and try to see what is going on. A snapshot won't really help.
Just to update this thread,I hooked my AutoTap scanner up and noticed the Bank 1 02 was not fluctuating like bank 2.It would'nt even fluctuate over 30mv's.New 02 sensor fixed my problem.
Thanks,
JE
Thanks,
JE
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
zajones
Jul 30, 2015 02:18 PM
