universal x from summitt doesnt just hook right up!
Old Dec 30, 2005 | 11:19 PM
red96z's Avatar
it seems like the pipe would have to be bent or an extra piece added to fit in the x correctly. what gives??? i thought it was pretty straight forward install??
Old Dec 30, 2005 | 11:32 PM
1995greenTA's Avatar
Re: universal x from summitt doesnt just hook right up!
right, they dont just hook up. Kinda sucks. I thought it would to when first ordered one not thinking that it wouldnt. I still have mine for sale.
Old Dec 30, 2005 | 11:33 PM
actually mine is the 3 inch universal from jegs. The legs werent long enough anyway you aranged it to work.
Old Dec 30, 2005 | 11:40 PM
red96z's Avatar
well its got to work somehow! hopefully without a muffler shop!
Old Dec 30, 2005 | 11:50 PM
93black-ta's Avatar
what gives? i was about to by the kit. i assumed i was an easy install.
Old Dec 31, 2005 | 12:02 AM
Evil Eric's Avatar
I did mine with a 14" chop saw and a mig welder. It was the 2 1'2 universal X from Summit. From 3" collectors on Pacesetter's to dumps at the axle.
Old Dec 31, 2005 | 12:13 AM
94 BIGRED's Avatar
I did the same with mine with a little cutting and my mig also it just had to hammer the pipe from the driver side a bit to make it not rub the undercarriage. It should fit with no problem other then alittle elbow grease and patience!
Old Dec 31, 2005 | 04:06 AM
Compstall's Avatar
If I buy something that's "universal", I assume that the part I'm getting is CLOSE, but not perfect and may need modifications to make it work. Only once in a great while have I ever been lucky enough to get something "universal" that fit with no mods.
Old Dec 31, 2005 | 08:29 AM
30696bird's Avatar
I must be lucky, mine fit perfect.
Old Dec 31, 2005 | 10:00 AM
Cmr0z28's Avatar
I PM'd you about this dude.....like I said you can't slide the pipes into one another because they aren't long enough to reach the collectors that way. You can either weld it like I did with the pipes barely touching one another, or have a shop extend the pipes.
Old Dec 31, 2005 | 11:49 AM
93black-ta's Avatar
Cmr0z28,
so, just to get things perfectly clear, the two pipes that come off the headers are not long enough to fit in the x-pipe correctly so you must extend the the pipes?
how much do the pipes need to be extended? i'd guess it would be about 2 1/2" seeing as you said they barley touch.
i assumed it would be a perfect fit seeing as how so many people have it and i havent heard anything about cutting and welding.
Old Dec 31, 2005 | 12:56 PM
This was my exact problem. I didnt have a welder at the time nor extra pipe, so its still setting in the box. Couldnt find a shop anywhere to touch it with out cats so i ended up back with a y pipe I expected to be able to just clamp it together but i was wrong
Old Dec 31, 2005 | 01:21 PM
Cmr0z28's Avatar
Not sure exactly how long they would have to be extended, but it wouldn't be much. If you measure from the center of each collector, you can bring it to the exhaust shop and have them extend/weld it per your measurements.
Old Jan 1, 2006 | 03:00 PM
Originally Posted by 93black-ta
Cmr0z28,
returned your PM
Old Jan 1, 2006 | 04:11 PM
Mindgame's Avatar
Yep, they need to be extended (pipes coming off the headers) otherwise the driver-side pipe runs into the tranny cross-member. 2-1/2 to 3" should do the trick, but it just depends on how long the headers are. A friend's TPIS longtubes needed 2-1/2" added.
-Mindgame
ryanhilsgen
9
Sep 21, 2015 07:34 PM
jackpawt883
Sep 10, 2015 08:53 PM
Pwilson59
Sep 3, 2015 08:47 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Jul 17, 2015 02:47 PM
