Universal oxygen sensors?
Old May 28, 2009 | 04:48 PM
cyteone's Avatar
Question Universal oxygen sensors?
Hi, I have a 1994 Firebird Formula that's having some issues passing smog.
The diagnosis reads: Found Oxygen Sensors reading incorrectly on scanner as per the fuel mixture. Oxygen sensors do test at full range of voltage. The Ecm does not respond to a rich signal by shortening the pulse width at the injectors.
Recommend replacing fuel injectors and Ecm.
I replaced the fuel injectors with some used stock injectors from another 94 LT1, and I replaced the Ecm which I also had flashed to match my VIN.
It still wouldn't pass smog.
I have a couple of new oxygen sensors I bought for my 92 5.2 ltr Dodge Dakota that have been sitting in my garage since I sold the truck about a year ago. They are 4 wire sensors.
Could I use them in my Firebird and just splice the wires instead of using the factory connectors?
Would they work fine in my application, assuming the threads are the same size?
I'm not sure it would help my smog problem, but they were sitting around anyway.
They are Bosch oxygen sonsors and the part numbers are 15704, and 15729.
Any input would be greatly appreciated. Thanks.
Old May 28, 2009 | 04:51 PM
madhatter's Avatar
I wouldn't personally. I have tried many of the universal kits in the past and there always seems to be a problem.
Get a set of Delcos, Delphis, Densos, or even NGKs. Stay away from the Bosch.
ryanhilsgen
9
Sep 21, 2015 07:34 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
Jul 17, 2015 02:47 PM
