unibody repair
Old Jul 16, 2003 | 11:34 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
unibody repair
is it possible? or worth it?
i f*cked the car up pretty bad... but i think the only real totaling factor is the drivers rear "panel" is completely destroyed..
if the rear isn't bent... (lets pray) and i can fix the unibody, it might be salvagable...
Old Jul 16, 2003 | 11:42 AM
GreenZ28in503's Avatar
It would seem to me that unless the subframe itself is bent in the rear, that one could simply replace the rear quarterpanel. How badly was your axle bent?
Taking your car to a frame shop to have it measured would be a good idea. If it's still straight, then a parts car and a plasma cutter will do amazing things.
Old Jul 16, 2003 | 11:53 AM
frmula1's Avatar
i don't know if the axle is bent or not...
i have to find out some way..
the wheel was bent and the rotor is badly cracked
2QUIK6
Sep 17, 2016 02:31 PM
IndyZman
Oct 22, 2015 02:17 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Aug 10, 2015 07:03 PM
