unequal backpressure?
Old May 30, 2005 | 12:05 PM
superkia8's Avatar
Does anyone know if unequal backpressure will hurt your engine and performance or would the front 02s adjust for the difference in backpressure. I have a dual cat setup and one of the cats went bad and is rattling. I dont want to put allot of money into this setup because I plan to switch to an LS1 in the near future and will have to get new headers, y pipe and so on then. Im trying to find a cheap fix for this noisy cat? Any ideas would be greatly appreciated.
Thanks,
Rich
Old May 30, 2005 | 01:16 PM
bdc95ta's Avatar
Re: unequal backpressure?
there really cheap on ebay.
-b
Old May 30, 2005 | 03:17 PM
superkia8's Avatar
I should have mentioned that it is a random tech high flow dual cat setup. I dont know if I can just use a stock flow cat or does it have to be another high flow cat, would the difference in backpressure cause problems? Also are there high flows on there cheap too?
Thanks again!
Old May 30, 2005 | 09:46 PM
StickMaster's Avatar
yea there are high flows cheap on there, no i dont think it would make too much of a difference. you can pick up a carsound (p/n 94009 i think) for around $50, high flow
Zero_to_69
Advanced Tech
128
Jan 13, 2005 07:44 AM
detroit1994z28
May 23, 2004 07:28 PM
detroit1994z28
May 22, 2004 09:40 PM
KevinAce
May 13, 2003 04:31 PM
WipeOutXXL
Apr 7, 2003 12:50 AM
