No Backpressure????
Old May 23, 2004 | 04:07 PM
detroit1994z28's Avatar
No Backpressure????
I recently opened a discussion on my 94 camaro z28 about having to much backpressure. I made a mistake. My car which is a 94 camaro z28m6 currently installed a hot cam with headers, no cats, with the loudmouth. My car does not have any backpressure. And every time I drive it it builds up and makes a loud popping sound then my performance kicks - in. Do i need a muffler - becuase the loudmouth is basically a hollow pipe you can see right threw. Will a muffler help reduce that problem
Old May 23, 2004 | 04:25 PM
SlickBlack Z's Avatar
Re: No Backpressure????
Old May 23, 2004 | 04:47 PM
fredmr39's Avatar
yea im a little confused too....only thing I can tell you is your car has backpressure.....it can't have no backpressure, no exhaust is 100% eficient...
Why do you think a muffler would help your performance?
Old May 23, 2004 | 07:28 PM
kmook's Avatar
Advanced Tech Moderator
The less restrictive an exhaust is the better, dont worry about backpressure. As far as your problem, it sounds like maybe tuning or something else is your problem if you 'performance' kicks in.
Zero_to_69
Advanced Tech
128
Jan 13, 2005 07:44 AM
detroit1994z28
May 22, 2004 09:40 PM
nat
Nov 5, 2003 11:59 PM
KevinAce
May 13, 2003 04:31 PM
WipeOutXXL
Apr 7, 2003 12:50 AM
