Underdrive Pullies, Electric Waterpump
Re: Underdrive Pullies, Electric Waterpump
CSI electric waterpump install done !!! Removal and installation was a breeze. the biggen pain in the *** was grinding room for the "ears" from the CSI pump into the waterpump housing. Afterwards it STILL would not fit....I was going crazy. Then I realized the csi pump diameter was about .005 bigger then the waterpump housing, So after running the grinder around the housing real quick it fit perfect. So far I am happy
Originally Posted by dmoor88
what all did you have to remove to install the elec. WP? im about to get a brand new csi off of a board member and its already in a housing.
if you were to use your current housing you would have to remove the internals of the mechanical pump and do so grinding. all the info is located here.
http://ken.lowrance.com/projects/CSIwaterpump/
if its already in teh housing then you have nothing to do but install it on the engine and run the wiring.
Alright, its time to hijack this thing.
What % ASP pulleys did you guys used? I am looking into perhaps investing in one, but I cant figure out the best % to go with. Obviously I want the best gains without killing my battery daily.
P.S. Scroggin Dickey mention earlier now sells CSI's for $135.99. And in case you didnt know most people buy them used for more than that.
-Dustin-
-Dustin-
tdigger9899
Sep 7, 2015 10:56 AM
