Underdrive Pulley's
Old Jul 9, 2004 | 10:18 AM
93LT1BIRD's Avatar
Underdrive Pulley's
IS UNDERDRIVE PULLEY'S WORTH THE MONEY? IF SO WOULD I WONT TO BUY THE ONE CRANK PULLEY OR BOTH THE CRANK AND THE ALTERNATOR PULLEY.
ALSO DOES ANYONE KNOW WHAT BELT I WOULD NEED IF I INSTALL THE PULLEY'S?
Old Jul 9, 2004 | 10:46 AM
Limited value, not a lot of "bang for the buck":
http://www.ws6.com/mod-2.htm
There are several options....
Piggy-back pulley (sandwiches between stock damper and hub) or full replacement integrated pulley/damper.
Crank pulley only, 25% or 35% U/D
Alternator U/D pulley - decreases alternator pulley speed even more, but can lead to charging problems at stock idle speed.
Alternator O/D pulley - increases alternator speed to prevent battery drain with large audio systems, etc.
Which belt you will need depends on the exact pulley you buy... size, number and manufacturer.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
