underdrive pulley question
Old Jan 29, 2006 | 05:48 PM
87lt1rx7's Avatar
I got a set of underdrive pulleys from someone a while back and went to install them does the crank pulley go in front of the current pulley or replace it? I am afraid to take off the stock pulley as it appears to be a balancer as well and that would not be a good thing to take off a balancer. Any pictures or comments?
Old Jan 29, 2006 | 06:00 PM
wrd1972's Avatar
Re: underdrive pulley question
The OEM balancer/pulley bolts onto the front of the underdrive pulley. The two pieces are used in conjunction.
1. Break loose the 3 balancer bolts and the altonator nut while the belt is on.
2. Remove the belt.
3. Remove the three balancer bolts.
4. Using a 3 jaw puller, pull the OEM balancer/pulley off the crankshaft.
5. Install the OEM balancer/pulley on top of the underdrive pulley and bolt them up using the longer bolts and torque to 65#.
6. Remove the altonator pulley nut and pulley.
7. Install new pulley and torque to snug.
8. Replace the belt and ensure it is tracking correct.
Old Jan 29, 2006 | 06:25 PM
87lt1rx7's Avatar
I just finished a few minutes ago on the pullies. anyone have a part number on the belt I need? I know the whole measuring process and getting the length, but just wanted to see if anyone had the part number handy
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
94z28jbw
Sep 8, 2002 03:22 PM
