Underdrive pulley opinions
Re: Underdrive pulley opinions
They produce a small power savings. ws6.com has a dyno test, showing only 0.7 peak HP, but a larger average increase in power at the wheels.
http://www.ws6.com/mod-2.htm
Depending on the underdrive ratio and whether or not you also install an underdrive alternator pulley, or try to recover alternator capacity at idle with an overdrive alternator pulley, you may see inadequate system voltage at idle with accessories on.
And, there are a couple different designs.... one that sandwiches between your stock damper/pulley and adds rotating weight, and another that totally replaces the damper/pulley. The latter is a better design, but a lot more expensive.
RUENUF
Mar 13, 2016 03:37 PM
