underdrive pulley=diff. size belt?! Where to get GATES
Old Jul 3, 2005 | 05:18 PM
AlwaysCode390's Avatar
Question underdrive pulley=diff. size belt?! Where to get GATES
I got an underdrive pulley set and it said to use a Gates belt # 847601. Where do I get that belt. I am guessing I NEED to use that belt .... because when I use the pulley set I need a different sized belt right?! Thanks-
Old Jul 3, 2005 | 05:25 PM
sbs's Avatar
sbs
Re: underdrive pulley=diff. size belt?! Where to get GATES
http://www.gates.com/automotive/dist...ocation_id=539
Old Jul 3, 2005 | 08:02 PM
Thumbs up Re: underdrive pulley=diff. size belt?! Where to get GATES
That was PERFECT, thanks alot....I found a belt 10 min away
Old Apr 5, 2010 | 07:26 AM
This is for self reference.
ASP underdrive pulley 34% crank and 15% alternator, part # 847601 uses:
Gates belt # K060598 ($25) - 60 3/8" v-belt (stock is 64 1/4") ---
Old Apr 5, 2010 | 07:34 AM
Other brands for same belt length ---
GOODYEAR GATOR BELT # 4060600
NAPA # 25060598
GATES # k060598
DAYCO # 5060600
Good link for belt swap info ... start at crank, end at crank after tensioner moved (13mm, 1/2") ---
https://www.camaroz28.com/forums/sho...ight=belt+swap
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 7, 2015 03:01 PM
racecarz28
Mar 30, 2015 09:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
