Under intake manifold plate rust...
Old Jan 27, 2007 | 12:56 PM
always faster's Avatar
I got a lt4 intake manifold and the under plate got some little spot of rust on it.
What should i do with it:
-Leave it like this?
or
-Sand it and thats it ?
or
-Sand it and paint it?
Thank you
Old Jan 27, 2007 | 01:14 PM
OBE1 95Z28's Avatar
That part is non-painted steel and will rust if exposed to air and moisture. I'd use a scotch brite pad and knock the rust off it. Make sure to blow the part off when done. Then take a rag and wipe some oil on it. When mounted on the car it won't rust as it will be oil covered as oil splashes in the lifter valley.
Old Jan 27, 2007 | 01:15 PM
JP95ZM6's Avatar
I wouldn't paint it. You don't want any paint flaking off in there. Bare steel inside valley is well enough protected by all the oil.
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
sbusaidi90
N2O Tech
Apr 22, 2015 06:51 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
