Ultimate castings for LE2 portwork
Old Dec 22, 2006 | 04:26 PM
cino's Avatar
I asked this in another thread, but did not get the clear answer.
What are the best aluminium heads to get ported by Lloyd Elliot? I know it is not the thin wall 561s. Is it 374s or 643s?
Old Dec 22, 2006 | 04:27 PM
MeanGreen97Z's Avatar
They 374s and 643s are pretty close but its the 643 castings that he asks for.
Old Dec 22, 2006 | 05:48 PM
1racerdude's Avatar
Sb 2.2
Old Dec 22, 2006 | 07:42 PM
sbs's Avatar
sbs
Originally Posted by 1racerdude
Sb 2.2
Old Dec 26, 2006 | 05:42 PM
sam pace's Avatar
true but what is involved for a conversion?
Old Dec 26, 2006 | 08:20 PM
rickreeves1's Avatar
561s, 374s, or 643s? I'm guessing this refers to LT1, LT4, etc.. Please clarify. What about trickflows? Would they be better for porting?
Old Dec 26, 2006 | 09:29 PM
Joe B's Avatar
Yea, they are refering to the most preferable (for all out port work) factory LT1 Castings......the aftermarket trickflows, as well as AFR heads have slightly even more potential when all out portwork is conserned.....PS:..you should have the most desirable factory LT1 casting 10207643 heads like I have on my 95 vette
Old Dec 26, 2006 | 10:19 PM
reamo04's Avatar
newb question, how do u know your casting numbers?
Old Dec 26, 2006 | 10:48 PM
...you take a peek under the valve cover...
Old Dec 26, 2006 | 11:15 PM
airflowdevelop's Avatar
Edelbrock 77549
Old Dec 27, 2006 | 02:06 AM
slomarao's Avatar
Some say the trickflows aren't worth the money considering the stock casting can come close to them. So why spend the money? If you have deep pockets or a high goals you should think about AFR's. Lloyd or AI can work wonders with a set of 210,220's.
Old Dec 27, 2006 | 06:26 AM
IllusionalTA's Avatar
Originally Posted by airflowdevelop
Edelbrock 77549
420.00 a head.. I'll take two...
Old Dec 27, 2006 | 08:41 AM
METALBEAST's Avatar
Only problem with AFRs is wait time. I ordered a set of 210s a couple of years ago and it took nearly 6 months to get them. Changed my plans, sold them and just had Lloyd port my stock castings.
Old Dec 27, 2006 | 02:09 PM
snakeatinZ's Avatar
Which heads flow the best stock? Or are the the same?
Old Dec 27, 2006 | 02:31 PM
Projectz28's Avatar
Moderator
stock the 561's are the better flowing heads with no work. Most of the porters like LE seem to want the 643's for porting an all out head from a stock casting. The AFR's and TFS heads have more potential as far as porting and also have thicker deck for bigger chambers. Some people go that route (myself included) because a stock casting will not allow you to run a domed piston and higher compression while retaining big chamber. The AFR's are impossible to get and just not worth the wait so the TFS heads have become the aftermarket head of choice by default. Personally I think they are a better / nicer head anyway.
