uh oh, another pacesetter lt question
Old Jan 3, 2005 | 11:50 PM
speed fiend's Avatar
I know, another damn pacesetter lt question. Sorry, but did the search and could not find the answer that I need and was hoping that someone with a lowered car running the pacesetter lt's could help me out. I would like to ask if any of you lowered guys out there could do me a favor and measure the amount of clearance from ground to lowest point of the collector or y-pipe. There is some speed bumps at work that I just cannot avoid and I'm trying to decide if its going to be worth the amount of trouble/scraping that I'm sure I'll be getting if I go LT's.
Old Jan 4, 2005 | 12:20 AM
Birdman7389's Avatar
Re: uh oh, another pacesetter lt question
FWIW, my car is not lowered, but I have not scraped on ANYTHING. Not big speedbumps or driveways.....
Old Jan 4, 2005 | 02:20 AM
DarkKnightZ28's Avatar
Well without going outside in the rain to measure my clearance I can tell you off hand that they do hang pretty low cause I have scraped some high speed bumps and some steep driveways. I try to be as careful as possible but there are just some speed bumps I have'nt been able to cross without some scraping. I'd have to guess between 3 and 4 inches.
Old Jan 4, 2005 | 08:48 AM
Z-RATED94's Avatar
Mines lowered and has the Pacesetters on it. I have about 3 and a half inches of clearance. I'm using the Eibach Pro's. Hope that helps ya.
Old Jan 4, 2005 | 08:53 PM
Thanks for the info, this really helps me out alot. I think I can live with having around 3 1/2" of clearance, just gotta be real careful right? Z-rated and DarkKnight, you guys have any regrets with your lt's and ground clearance issues? Getting really close to convincing myself that its ok to get the lt's instead of mid lengths.
Old Jan 4, 2005 | 09:29 PM
Z-RATED94's Avatar
No regrets here, had the shortys and figured the heads and cam deserved the LT's. I will sooner or later raise the front half an inch or so with some QA1's. I need some better weight transfer anyways.
Old Jan 5, 2005 | 01:58 AM
No regrets here either, the car sounds great and pulls harder and the clearance is not that bad as long as your careful and do the lowrider thing over the big bumps (drive over them at an angle). But yeah go for it man!
Old Jan 5, 2005 | 03:59 AM
Aalll riiiight, thats what I wanted to here! Guess I'll be ordering mine soon. Just looking around for the right place to order from. Thanks guys, really appreciate it.
WildRidez
Mar 27, 2015 08:22 AM
alex5366
Feb 17, 2015 09:07 AM
LT14LIFE
Feb 9, 2015 09:35 PM
Brad 97z
Aug 10, 2002 09:58 AM
