UGHH...car shutting off
Old Dec 28, 2006 | 10:40 AM
CHELOZ28's Avatar
Well my problem started a couple of weeks ago, my car would just shut off at
red light and today on the way to work it did twice once at a Light the second time when I was turning into a parking space. My SES light turns on and than goes away doing this at WOT.....also when I warm up my car there is times when the rpms raise to 2000 without me giving it some gas, when the car does shut off the check guages light is on. I was told by a mechanic that its my Granatelli MAF
Old Dec 28, 2006 | 12:38 PM
2000GTP's Avatar
Scanning the car for codes would be a good start seeing that your SES light turned on.
Old Dec 28, 2006 | 12:57 PM
'94 Bad A Z28's Avatar
Sounds to me like your ignition switch may be on it's way out.
It's like a $17 or $27 part from the dealer, but a PITA to put in.
Old Dec 28, 2006 | 06:02 PM
CHELOZ28's Avatar
The only bad thing is that my ses light turns on for a little than goes away.
Can they still read a code even is the ses light is not on? Where is the ignition switch, might just change it tomorrow. Anyone else think thats its the ignition switch....
Old Dec 28, 2006 | 06:28 PM
OBE1 95Z28's Avatar
Sounds like you have a couple of issues. Your computer will store codes so they can be retrieved even if your SES is off.
If you decide to replace your ignition switch, Shoebox has a good write-up: http://shbox.com/ignsw/ign_switch_repl.html
Old Dec 29, 2006 | 02:18 AM
It's a PITA to get to it is on the topside of the steering colum. You have to drop the steering wheel down and try to get your arm/hand up there.
Old Dec 29, 2006 | 10:56 AM
Rare96Formula's Avatar
I'd check to make sure your MAF sensor is functioning like it should. If thats not the issue my guess is you have a vacuum leak somewhere. My 96 formula did some of the same things you mentioned when it had a pretty bad vacuum leak . My car would rev up on its own at a stoplight and die out sometimes. Check your vacuum lines to make sure there isn't a leak!
Good Luck!
Old Dec 29, 2006 | 01:02 PM
CHELOZ28's Avatar
im going to chek it for codes today, I will post whatever they tell me.
Also my vacuum check valve and also vacuum canister have broken off, it makes this loud hiiiss noise at idle.....could that be it?
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
KYWes
Sep 26, 2015 08:49 AM
Greg88
Sep 20, 2015 07:14 PM
