two step wiring
Old Nov 16, 2004 | 10:21 PM
my94blackz's Avatar
two step wiring
Who has wired there 6 speed up to a two step? How did ya do it? I want to mount mine to the nuetral safety switch and put it on a toggle switch, how do i go about this? The neutral safety switch has 2 wires yellow and brown which is hot? i tried it earlier tonight but got nothing, im using the msd digital 6. The two step works we run the wire strait to the battery. I want to be able to arm the two step with a toggle and activate it with the clutch some how. I just dont kno how to wire it into the nuetral safety switch. any ideas?
Old Nov 16, 2004 | 11:18 PM
whitehooptie's Avatar
Re: two step wiring
I just put mine on a button
Old Jun 8, 2006 | 09:46 PM
my94blackz's Avatar
Re: two step wiring
How could you be consistant with droppin the clutch and releasing button? Plus All this at one: Good reaction, clutch drop, release button, shift, hammer the throttle, feel for spin, feather (if needed), watch tach, thats alot of stuff to do at once. There got to be something easier.
Old Jun 8, 2006 | 10:00 PM
Spitfire557's Avatar
Re: two step wiring
Hate to sound like a *****, but you could just buy an automatic.
Old Jun 8, 2006 | 11:57 PM
Re: two step wiring
Well, you drop the clutch a **** hair after you release the button. You should already be in a gear before you go. The throttle is probably all of the way down to the floor, DR or slicks there should be no spin, ywhy watch the tach when a shift light will work and you can see it out of the corner of your eye. Or as the other guy said, get an auto.
It is like riding a motorcycle. 15 million things to do at once. Do it a few times and it goes in a quick motion. But on your defense, a 6 speed and two step is not very consistant unless you work out all of the bugs.
My god this is an OLD thread. Check the board often?
Old Jun 9, 2006 | 09:04 AM
my94blackz's Avatar
Re: two step wiring
Forgot I posted it. I do that all the time. I was thinking of it again last night and dyg it up. I posted it then never looked at it again.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
